[postgis-devel] [PostGIS] #1668: ST_AsText, ST_AsEWKT under Windows 64-bit PostGIS 64-bit is all screwy
trac at osgeo.org
Thu Jul 19 19:52:35 PDT 2012
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: mingw64 |
Comment(by robe):
Paul and Mark -- if all you got is a 32-bit, I have the same issue
building PostGIS under the mingw64-w32 chain for PostgreSQL 9.2. So I am
using the same hacks as I did for mingw64-w64. I can package up my ming32
folder if you are interested (with all the prec-compiled proj,geos,etc
libraries so you can extract and get to work :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1668#comment:47>
