[postgis-devel] [PostGIS] #1929: regression issue: ST_Polygon used to return simplest polygon
trac at osgeo.org
Sun Jul 22 19:31:39 PDT 2012
Reporter: robe | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: raster | Version: trunk
Keywords: |
Comment(by dustymugs):
I actually prefer the multipolygon behavior as it guarantees that the
output will always be multipolygon. Another thing that did change with
the C version is that the code will validate that the union of the pixel
polygons is valid and if not will call GEOS's make-valid function.
I'll double-check the changes you made in r0086 and add any revisions.
Once I've done that, I'll close this ticket.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1929#comment:2>
