[postgis-devel] [PostGIS] #1930: Missing fields from tabblock table in tiger2011 census loader
trac at osgeo.org
Mon Jul 23 09:05:40 PDT 2012
Reporter: bpanulla | Owner: robe
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.0.2
Component: tiger geocoder | Version: trunk
Keywords: |
Similar to #1885, the TIGER 2011 Geocoder has some issues with the
tabblock table. The loader throws the following error in the logs:
NOTICE: INSERT INTO
tiger_data.ca_tabblock(the_geom,intptlon,intptlat,awater,aland,funcstat,uace,ur,mtfcc,name,tabblock_id,blockce,tractce,countyfp,statefp)
SELECT
the_geom,intptlon,intptlat,awater,aland,funcstat,uace10,ur10,mtfcc,name,tabblock_id,suffix1ce,blockce10,tractce10,countyfp10,statefp10,countyfp,statefp
FROM tiger_staging.ca_tabblock;
CONTEXT: SQL function "loader_load_staged_data" statement 1
ERROR: INSERT has more expressions than target columns
LINE 1: ...block_id,suffix1ce,blockce10,tractce10,countyfp10,statefp10,...
The extra fields in the staging table generated by the shapefile loader
are:
statefp CHARACTER VARYING(2),
countyfp CHARACTER VARYING(3),
suffix1ce CHARACTER VARYING(1),
The statefp and countyfp fields are accompanied by statefp10 and
countyfp10, so I'm not sure which pair is actually extra.
I haven't noticed any problems with the functionality of the Geocoder.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1930>
