[postgis-devel] [PostGIS] #1937: must specify "true" to st_length when casting to geography
trac at osgeo.org
Thu Jul 26 08:30:53 PDT 2012
Reporter: bcrosby | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.2
Component: postgis | Version: 2.0.x
Resolution: invalid | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => invalid
Comment:
I suspect your upgrade was dirty and you did not run the
postgis_upgrade_20_minor.sql after restoring ontop of a new PostGIS 2.0.1
database.
This is one change -- a lot of functions were changed to use default args,
so simply restoring ontop of a PostGIS 2.0.1 will not work.
To fix:
Run postgis_upgrade_20_minor.sql
If you installed using extensions, then you will need to just run all
the drop statements at the end of that script.
Actually the drop statements is really all you need. I was just didn't
want to confuse people by explaining that.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1937#comment:1>
