[postgis-devel] type agg_samealignment does not exist
Bborie Park
dustymugs at gmail.com
Tue Jul 31 08:41:20 PDT 2012
On Tue, Jul 31, 2012 at 8:03 AM, Salvatore Larosa <lrssvtml at gmail.com> wrote:
> Hi,
> Il giorno lun, 25/06/2012 alle 15.00 -0700, dustymugs ha scritto:
>> Salvatore,
>> I'm guessing you're looking to move up from PostGIS 2.0.x to PostGIS
>> -trunk? If so, you can't use rtpostgis_upgrade_20_minor.sql as-is since
>> that upgrade file is for upgrading within the 2.0 code base.
>> Since you're trying to use -trunk, I'm assuming you don't mind some
>> risk. You can still use rtpostgis_upgrade_20_minor.sql with the
>> following modification though...
>> Look for the following function:
>> CREATE OR REPLACE FUNCTION _st_samealignment_transfn(agg
>> agg_samealignment, rast raster)
>> Before that line, provide the following:
>> CREATE TYPE agg_samealignment AS (
>> refraster raster,
>> aligned boolean
>> That should take care of the agg_samealignment missing issue.
>> -bborie
> I upgraded to the latest trunk and I am getting alike error with
> addbandarg[] type:
> rtpostgis_upgrade_20_minor.sql:743: ERROR: type addbandarg[] does not
> exist
> so I following your hint and added this in
> CREATE TYPE addbandarg AS (
> index int,
> pixeltype text,
> initialvalue float8,
> nodataval float8
> before of:
> CREATE OR REPLACE FUNCTION st_addband(rast raster, addbandargset
> addbandarg[])
> Then I re-run the script and I get:
> rtpostgis_upgrade_20_minor.sql:4330: ERROR: operator does not exist:
> raster && geometry
> LINE 3: AS $$ SELECT $1 && ST_Expand(ST_ConvexHull($3), $5) AND $3 ...
> HINT: No operator matches the given name and argument type(s). You
> might need to add explicit type casts.
> Any idea on how solves it?
> Kind Regards,
> -SL
> Salvatore Larosa
> linkedIn: http://linkedin.com/in/larosasalvatore
> twitter: @lrssvt
> skype: s.larosa
> IRC: lrssvt on freenode
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Gah! It looks like I forgot to explicitly set some type casts. You'll
want to use r10144 from trunk.
-bborie
