[postgis-devel] [PostGIS] #1802: Ensure interruptability of long-running calls
PostGIS trac at osgeo.org
Wed Jun 6 03:57:03 PDT 2012
 Reporter:  strk     |       Owner:  strk
     Type:  task     |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by strk):
 So in r9850 we do have the signal handling code protected by a
 POSTGIS_ENABLE_GEOS_INTERRUPTIBILITY macro, undefined by default.
 If you are not building against GEOS-3.4.0+ you can't define the macro
 (it's undefined later in this case).
 This should make it very easy for anyone to test.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1802#comment:19>
