[postgis-devel] Query interruptibility in stable branch
Paul Ramsey pramsey at opengeo.org
Wed Jun 6 08:08:18 PDT 2012
I have no objection to code that is #defined as disabled being added.
In fact I wanted to add some (the new rtree splitting approach prior
to 2.0) recently.  That being said, why not just maintain a branch at
github with your changes for client purposes? I've done that (actually
SVN spikes) many times in the past for folks on MapServer features.
P.
On Wed, Jun 6, 2012 at 6:51 AM, Sandro Santilli <strk at keybit.net> wrote:
> Moving the discussion on #1802 here.
> The problem that ticket is trying to address is the uninterruptibility
> of some processor and memory intensive queries.
> An example such query is:
>  select st_buffer(st_collect(geom), 1e5, 15) from (
>   select (st_dumppoints(st_buffer(st_point(0,0), 1e4, 150))).geom
>  ) as foo;
> If you run that query the memory used by postgres will start growing
> and the CPU will be spinning at 100% for more than a few seconds
> (around one minute here). Note that this is a simple example, I've
> found myself more than once in need to send a SIGKILL to the backend
> in order to get control of the machine back.
> Normally, hitting ^C, or setting a timeout (set statement_timeout)
> helps you in getting out of troubles. But some functions just don't
> obey to that command. All the GEOS implemented function are of this
> kind. Ironically, they are usually the ones that make your CPU spin
> and drink all your memory.
> Now, starting with GEOS-3.4.0 (unreleased yet), there is a way to
> request interruption of running operations, but it is up to the
> client code to request such interruption.
> I've committed code in trunk to request the interruption of GEOS
> operations on receiving SIGINT, which is the signal received on
> hitting ^C or expiring the statement_timeout time. The code in
> trunk always installs the signal handler, but only request
> interruption of GEOS if supported (GEOS-3.4.0+ at build time).
> In the ticket we're debating whether to make this functionality
> available in the 2.0 branch or not.
> For now I committed a _disabled_ version of the code in the 2.0 branch
> that you can bring up by defining a macro. The version in 2.0, if enabled,
> is less invasive in that it doesn't install the signal handler unless
> GEOS version is 3.4.0 or higher (SVN, at time of writing).
> I'm ready to revert the change, but I don't think it hurts anyone,
> being disabled by default, while it will help anyone willing to retain
> the power to interrupt an harmful query w/out playing gunfighting nor
> jumping on the 2.1 branch (which means giving up stability).
> Mark gave his +1 for reversion. I'll be -0 here.
> --strk;
>  ,------o-.
>  |   __/  |    Delivering high quality PostGIS 2.0 !
>  |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
>  `-o------'
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
