[postgis-devel] [PostGIS] #1855: 'SQL/MM Spatial exception - curve not simple' exception at adding two polygons
trac at osgeo.org
Thu Jun 7 07:30:44 PDT 2012
polygons
Reporter: wimned | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.1
Component: topology | Version: 2.0.x
Keywords: |
Comment(by strk):
Those functions are expected to split whatever you pass in input and
always succeed. An exception is a bug. Robustness related, most likely.
Changes are this was already fixed with GEOS-3.3.4.
Can you show your postgis_full_version() ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1855#comment:1>
