[postgis-devel] [PostGIS] #1802: Ensure interruptability of long-running calls
trac at osgeo.org
Thu Jun 7 08:22:05 PDT 2012
Reporter: strk | Owner: strk
Type: task | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by strk):
Alright, more changes, more testing needed ...
Robe: could you please try building r9857 of PostGIS after installing r
3672 of GEOS ?
Better if you do with WIN32 as the change is using a WIN32 macro (as found
in postgresql source code) which may or may not be defined with win64.
Since we check for GEOS version to enable or not interruption anyone with
a non up-to-date GEOS-3.4SVN wont be able to build for windows.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1802#comment:25>
