[postgis-devel] [PostGIS] #1848: raster regress failure on mingw mapalgebraexpr, rt_clip
PostGIS trac at osgeo.org
Thu Jun 7 08:59:13 PDT 2012
 Reporter:  robe    |       Owner:  pracine
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:  PostGIS 2.0.1
Component:  raster  |     Version:  2.0.x
 Keywords:          |
Comment(by dustymugs):
 Strange set of regression failures as the functions failing aren't related
 and functions related to the ones failing aren't.
 The mapalgebraexpr failure appears to be caused by a rounding issue.  The
 specific test that is failing is rounding a pixel value of 27.5, which
 could go to 27 or 28 depending on the platform.  I'm going to change the
 round() to a ceil() as that should be more consistent across all
 platforms.
 It looks like the output queries in rt_clip aren't explicitly ordered like
 they should.
 Can you try r9858 for 2.0?  I've also committed the change for trunk in
 r9858.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1848#comment:2>
