[postgis-devel] [PostGIS] #1822: topology won't install on PostgreSQL 9.2beta1
trac at osgeo.org
Thu Jun 7 15:35:54 PDT 2012
Reporter: robe | Owner: strk
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 2.0.1
Component: topology | Version: 2.0.x
Resolution: | Keywords:
Comment(by strk):
Replying to [comment:8 robe]:
> I only see it at the end and I think I even added it
http://trac.osgeo.org/postgis/browser/trunk/topology/topology.sql.in.c?rev=9748#L1987
> (and I think I added that because I needed it for the SQLManagement to
know whether I can DO or not DO. We won't be needing that check anymore
for 2.1.0 once you upgrade from your crappy 8.4 and 9.0 is the minor.
Then I can be DOing all I want :).
> does the fact that your check happens before the variable is defined
matter?
Yes, it does!
Please move it on top and see if it works for you.
I probably didn't check as I don't have 9.2 built.
> Well the POSTGIS_PGSQL_VERSION I presume is something screwy with our
parsing.
> The version is 9.2beta1
> Seems like its picking up the 1 part as part of version number.
Could you file a separate bug for this ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1822#comment:9>
