[postgis-devel] [PostGIS] #1860: geometry regression tests not raster safe
PostGIS trac at osgeo.org
Tue Jun 12 01:22:33 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.2
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
 I'm still getting a lot of crashing when testing against VC 64-bit EDB
 builds for 9.0 and 9.1.  I tried to run these outside of mingw to see if
 they crash by themselves, but I quickly ran into obstacles.
 It seems a lot of our tests e.g. regress.sql
 use constructs like
 ST_SRID('POINT(1 2)')
 which if you have raster installed gives a st_srid(unknown) is not unique
 errors.  I think we have quite a few of these that need to be changed to
 ST_SRID('POINT(1 2)'::geometry)
 Anyrate I have managed to crash my 9.0x64bit after some runs, outside of
 mingw environment so separate issue.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1860>
