[postgis-devel] [PostGIS] #1798: Performance issue with ST_Intersects(geometry, geometry)
trac at osgeo.org
Wed Jun 13 09:00:06 PDT 2012
#1798: Performance issue with ST_Intersects(geometry,geometry)
Reporter: nicklas | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.1
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by nicklas):
EXPLAIN
SELECT count(*)
FROM polygons , points
WHERE ST_Intersects(points.geom , polygons.geom);
9.1:
Aggregate (cost=54835.03..54835.04 rows=1 width=0)
-> Nested Loop (cost=0.00..54835.03 rows=1 width=0)
Join Filter: ((points.geom && polygons.geom) AND
_st_intersects(points.geom, polygons.geom))
-> Seq Scan on points (cost=0.00..1834.00 rows=100000
width=128)
-> Materialize (cost=0.00..1.03 rows=2 width=32)
-> Seq Scan on polygons (cost=0.00..1.02 rows=2 width=32)
(6 rows)
8.4:
Aggregate (cost=56169.02..56169.03 rows=1 width=0)
-> Nested Loop (cost=0.00..56169.02 rows=1 width=0)
width=128)
(5 rows)
As I understand it in 8.4 the sequantal scan takes one polygon at a time
and iterate all points. But in 9.1 it takes one point at a time iterating
all polygons which makes preparing the polygon just slowing things down.
But from PostgreSQL perspective there is no right and wrong I guess?
Or can we manipulate this behavior?
Is this something like the same issue that causes us to expand both first
and second geoemetry in the sql-definition of ST_DWithin. If I remember
right Regina said something like that.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1798#comment:14>
