[postgis-devel] [PostGIS] #1798: Performance issue with ST_Intersects(geometry, geometry)
trac at osgeo.org
Fri Jun 15 02:47:14 PDT 2012
#1798: Performance issue with ST_Intersects(geometry,geometry)
Reporter: nicklas | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.2
Component: postgis | Version: 2.0.x
Keywords: |
Changes (by strk):
* milestone: PostGIS 2.0.1 => PostGIS 2.0.2
Comment:
doesn't sound something that will be fixed in 2.0.1 -- not even sure we
can call this a bug.
if you want to debug caches being used you can enable debugging in
postgis_config.h
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1798#comment:17>
