[postgis-devel] [PostGIS] #1848: [raster] regress failure on mingw mapalgebraexpr, rt_clip
PostGIS trac at osgeo.org
Fri Jun 15 03:08:30 PDT 2012
 Reporter:  robe    |       Owner:  dustymugs
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:  PostGIS 2.0.1
Component:  raster  |     Version:  2.0.x
 Keywords:          |
Changes (by robe):
  * owner:  robe => dustymugs
Comment:
 Back to you dustymugs.
 It's better. rt_clip is still failing.
 rt_clip .. failed (diff expected obtained: /tmp/pgis_reg/test_54_diff)
 I've attached the diff.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1848#comment:7>
