[postgis-devel] [PostGIS] #1828: Estimate returned by geography_gist_selectivity results in slow query plan for ST_DWithin
trac at osgeo.org
Fri Jun 15 10:57:32 PDT 2012
for ST_DWithin
Reporter: realityexists | Owner: mcayland
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.1
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by strk):
rewind, I take it back. The estimator is called anyway.
For geometry the query must be changed to :
SELECT count(id) FROM _test_pos
WHERE geom && ST_Buffer('SRID=4326;POINT(7 7)', 1);
Here's some debugging from the selectivity estimator:
NOTICE: [geometry_estimate.c:geometry_gist_sel_2d:653] geometry_gist_sel
called
NOTICE: [geometry_estimate.c:estimate_selectivity:446] histogram has 126
cols, 127 rows
NOTICE: [geometry_estimate.c:estimate_selectivity:447] histogram geosize
is 19.999001x19.999001
NOTICE: [geometry_estimate.c:estimate_selectivity:591] search_box
overlaps 182.000000 cells
NOTICE: [geometry_estimate.c:estimate_selectivity:592] avg feat overlaps
1.000300 cells
NOTICE: [geometry_estimate.c:estimate_selectivity:604]
SUM(ov_histo_cells)=0.096025
NOTICE: [geometry_estimate.c:estimate_selectivity:605] gain=0.999700
NOTICE: [geometry_estimate.c:estimate_selectivity:606]
selectivity=0.095996
NOTICE: [geometry_estimate.c:geometry_gist_sel_2d:754] returning
computed value: 0.095996
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1828#comment:17>
