[postgis-devel] [PostGIS] #1869: ST_AsBinary is not unique (again)
trac at osgeo.org
Fri Jun 15 14:07:58 PDT 2012
Reporter: nidi | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone:
Component: postgis | Version: 2.0.x
Resolution: wontfix | Keywords:
Comment(by robe):
I can see this biting a lot of people (heck even our regression tests have
issues). I know the solution is for people to fix their apps, but strk --
you think it would be bad if we put in as part of the legacy sql installs
ST_AsBinary(text) , ST_SRID(text) and some of the other common ones. That
was the work-around we put in when geography came on the scene. I think
we might have taken some of the wrappers out.
At the very least, I guess we should have this in the docs as a breaking
change if we don't already.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1869#comment:2>
