[postgis-devel] [PostGIS] #1873: ST_InterpolatePoint returns empty M value
trac at osgeo.org
Mon Jun 18 05:42:20 PDT 2012
Reporter: arho | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.1
Component: postgis | Version: 2.0.x
Keywords: |
If the interpolated point is directly on the line, M is 0:
'''Example - point not on line, correct M value:'''
SELECT ST_InterpolatePoint('LINESTRING M (0 0 0, 10 0 20)', 'POINT(5 5)');
st_interpolatepoint
10
'''Example - point on line, M value is 0:'''
SELECT ST_InterpolatePoint('LINESTRING M (0 0 0, 10 0 20)', 'POINT(5 0)');
st_interpolatepoint
0
'''Expected Result:''' 10
'''Version information:'''
POSTGIS="2.0.0 r9605" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.7.1, 23
September 2009" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8"
RASTER
PostgreSQL 9.1.2 on i686-pc-linux-gnu, compiled by gcc-4.6.real (Debian
4.6.2-4) 4.6.2, 32-bit
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1873>
