[postgis-devel] [PostGIS] #1875: [raster] ST_SummaryStats should return null stats on nodata rasters
trac at osgeo.org
Mon Jun 18 11:06:26 PDT 2012
Reporter: pracine | Owner: dustymugs
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.2
Component: raster | Version: 2.0.x
Keywords: |
Comment(by robe):
hmm -- your and Pierre's call I would say. Technically I guess you could
say its a change in behavior but then if you say the behavior was a bug in
the first place, then its a bug fix and can go in 2.0.1 as long its not an
invasive change that risks breaking something else.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1875#comment:2>
