[postgis-devel] [PostGIS] #1879: Export crashes shp2pgsql-gui
trac at osgeo.org
Wed Jun 20 09:36:36 PDT 2012
Reporter: bmmpxf | Owner: mcayland
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.1
Component: loader/dumper | Version: 2.0.x
Resolution: fixed | Keywords:
Changes (by bmmpxf):
* status: new => closed
* resolution: => fixed
Comment:
Thanks for the responses. I'm running Windows 7 32-bit, so I must have
downloaded the 32-bit version, via the standard installer. (Postgres
9.1.4) And shp2pgsql-gui is Revision 9583. Apologies, I should have sent
that information over initially.
I just tried with the experimental build marked "2.0.1SVN" and the export
worked fine, so I believe whatever it was has been fixed since last
release. Thanks, everyone.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1879#comment:3>
