[postgis-devel] [PostGIS] #1878: shp2pgsql-gui: Column contents have tangled values
PostGIS trac at osgeo.org
Thu Jun 21 04:14:18 PDT 2012
  Reporter:  bmmpxf         |       Owner:  mcayland
      Type:  defect         |      Status:  closed
  Priority:  medium         |   Milestone:  PostGIS 2.0.1
 Component:  loader/dumper  |     Version:  2.0.x
Resolution:  fixed          |    Keywords:
Changes (by robe):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 bmmpxf - thanks for the feed back.  yah I noticed the disappearing row
 too.  I wonder if I forgot to ticket that or couldn't come up with a
 consistent set of steps to replicate it.
 Anyway I think those items should be separate tickets (pushed to 2.0.2 and
 I'll close this one out).  As far as adjusting it seems the shapefile
 field on import is adjustable but that seems to be the only field. None of
 the export ones are.  Is that what you are noticing.
 If you can file those issues and UI improvements (as enhancements), that
 would be super :).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1878#comment:5>
