[postgis-devel] [PostGIS] #1882: regress failure st_asraster, st_resample on mingw64 9.1 mingw64 built 9.1
trac at osgeo.org
Thu Jun 21 08:41:15 PDT 2012
Reporter: robe | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.1
Component: raster | Version: 2.0.x
Keywords: |
Comment(by dustymugs):
It looks like GDAL is misconfigured as it appears that both failures have
to do with raster transformations resulting in a raster with the same
spatial attributes as in the input raster (though it shouldn't be). It
looks like the env variable GDAL_DATA may need to be set.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1882#comment:2>
