[postgis-devel] [PostGIS] #1881: shp2pgsql-gui -- editing a field sometimes triggers removing row
PostGIS trac at osgeo.org
Thu Jun 21 23:05:59 PDT 2012
  Reporter:  robe           |       Owner:  mcayland
      Type:  defect         |      Status:  closed
  Priority:  medium         |   Milestone:  PostGIS 2.0.2
 Component:  loader/dumper  |     Version:  2.0.x
Resolution:  fixed          |    Keywords:
Comment(by robe):
 Hey Mark,
 I just noticed something odd which  might be why I was confused about the
 stretching.  On my mingw64 shp2pgsql-gui compiled, I can stretch all the
 columns, but on my 32-bit one I can only stretch the first column of
 import tab.
 I thought I was using the same GTK build, but maybe my mingw64 gtk is
 newer.  I'll verify that.  Are you able to stretch all columns on the
 import tab?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1881#comment:9>
