[postgis-devel] [PostGIS] #1828: Estimate returned by geography_gist_selectivity results in slow query plan for ST_DWithin
trac at osgeo.org
Fri Jun 22 03:48:27 PDT 2012
for ST_DWithin
Reporter: realityexists | Owner: mcayland
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.2
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by strk):
Are you saying that ST_AsText(ST_Expand('POINT(0 0)'::geography)) would
return 'POINT(0 0)' ? If that's the case I'd consider it a bad bug indeed.
That said, wouldn't it be faster just to always use the cached bbox rather
than recomputing it ? Or is there any special need to recompute for
geography ? Or is it the old double vs. float story ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1828#comment:25>
