[postgis-devel] [PostGIS] #1884: st_centroid fails on a small polygon
trac at osgeo.org
Fri Jun 22 05:10:10 PDT 2012
Reporter: csandor | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.4
Component: postgis | Version: 1.5.X
Keywords: |
When I do this select on a very small polygon made of 3 points I get
an empty collection:
select ST_AsText(ST_Centroid(ST_GeomFromText('POLYGON((56.5286666667
25.2101666667,56.529 25.2105,56.5288333333 25.2103333333,56.5286666667
25.2101666667))')));
st_astext
GEOMETRYCOLLECTION EMPTY
(1 row)
If I modify one value just a little bit (56.529=>56.529000000001) I
get correct results:
25.2101666667,56.529000000001 25.2105,56.5288333333
25.2103333333,56.5286666667 25.2101666667))')));
st_astext
POINT(56.5288333333337 25.2103333333333)
(1 row)
Sandro Santilli confirmed it is bug.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1884>
