[postgis-devel] [PostGIS] #1828: Estimate returned by geography_gist_selectivity results in slow query plan for ST_DWithin
trac at osgeo.org
Fri Jun 22 10:08:02 PDT 2012
for ST_DWithin
Reporter: realityexists | Owner: mcayland
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.2
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by pramsey):
The patch does fix things, in that the query box now has a non-zero
extent... however the estimate is still way off.
postgis20=# explain analyze SELECT id FROM _test_pos WHERE ST_DWithin(pos,
'POINT(7 7)'::geography, 300000);
NOTICE: requested search box is : 0.938059508800507 0.0738726407289505
0.0747810378670692, 1.03223621845245 0.168049246072769 0.168957650661469
QUERY PLAN
Seq Scan on _test_pos (cost=0.00..5578.00 rows=1 width=4) (actual
time=17.239..67.544 rows=3839 loops=1)
Filter: ((pos &&
'0101000020E61000000000000000001C400000000000001C40'::geography) AND
('0101000020E61000000000000000001C400000000000001C40'::geography &&
_st_expand(pos, 300000::double precision)) AND _st_dwithin(pos,
'0101000020E61000000000000000001C400000000000001C40'::geography,
300000::double precision, true))
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1828#comment:32>
