[postgis-devel] [PostGIS] #1886: Outstanding release items for 2.0.1
trac at osgeo.org
Wed Jun 27 00:19:09 PDT 2012
Reporter: robe | Owner: chodgson
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.1
Component: management | Version: 2.0.x
Resolution: fixed | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
I think we are in good shape now. I figured out the last few bits. The
postgis 2.0 deploy has the scp line to copy the tar ball to the site
presumably to prevent 2.0.0 from being overritten. Now that I changed it
from tagged to branch, that's a non-issue so put the line back.
I also had to change the cms_config to properly display the postgis 2.0
branhc revisions.
Only minor thing to fix which I'll do later is that the release html
documentation is pointing at the branch build
http://www.postgis.org/documentation/
I think this just requires changing the symlink. I accidentally messed it
up when untagging and not changing another line. I'll fix that one later.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1886#comment:6>
