[postgis-devel] [PostGIS] #1215: ST_DelaunayTriangles
trac at osgeo.org
Wed Jun 27 07:19:19 PDT 2012
Reporter: strk | Owner: strk
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: |
Comment(by woodbri):
It seems to me that having something like:
select the_geom
from delaunay_triangles(sql_for_points text, tolerance double precision,
multilinestring_out boolean);
select the_geom
precision);
where the function returns a set of geometries based on
multilinestring_out flag. If true you get multilinestrings if false or
absent you get polygons. You mentioned a tolerance so I tossed that in,
but what is it for?
I like the set returning function because it is easy to throw
ST_Collection() around it if you want a collection but much harder to
explode it is you do not want that and it support your idea of pipelining.
BTW. Nice work on this!
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1215#comment:9>
