[postgis-devel] [PostGIS] #1630: upgrade from alpha6 to alpha7SVN: wktgeomval type can't be dropped; cannot change input parameter nodata
trac at osgeo.org
Thu Mar 1 00:28:26 PST 2012
Reporter: robe | Owner: strk
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 2.0.0
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords:
Comment(by pracine):
I guess the nodata array versions are missing in rtpostgis_drop.sql.in.c:
DROP FUNCTION IF EXISTS st_clip(raster, geometry, float8[], boolean);
DROP FUNCTION IF EXISTS st_clip(raster, int, geometry, float8[], boolean);
Would that do the job?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1630#comment:10>
