[postgis-devel] [PostGIS] #1641: SQL/MM Spatial exception - geometry crosses an edge
trac at osgeo.org
Thu Mar 1 02:25:54 PST 2012
Reporter: lrssvt | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: 2.0.x
Keywords: |
Running SQL script (attached file polyTopo) I get the following error for
my layer (attached file layerPoly).
ERROR: SQL/MM Spatial exception - geometry crosses an edge
CONTEXT: PL/pgSQL function "topogeo_addlinestring" line 143 at assignment
SQL statement "SELECT array_cat(edges, array_agg(x)) FROM ( select
topology.TopoGeo_addLinestring(atopology, rec.geom, tolerance) as x ) as
foo"
PL/pgSQL function "topogeo_addpolygon" line 23 at assignment
SQL statement "INSERT INTO poly_topo.relation(topogeo_id, layer_id,
element_type, element_id) SELECT 2, 1, 3, topogeo_addPolygon('poly_topo',
'0103000020BC0B0000010000000A000000640FEAD1CAC0DABFA8D653CFF82FE43F807A7AC40C63C9BF0CABC1DC9906E43FB8E2E5B7779ECCBF751D41DFF25ADE3F6084AF11173FC23FF783D649EFFDD93F803B8CFD12DBABBFAE520CA6A8F4C43F785AF3A726AEC93FA0F9F2CB618885BF00B612B697557ABFB4386EE1F850B9BF00CEDC644808873FFF54F94ABD5AC6BF18995CCF8903C0BF3A9BD621CEC4C3BF640FEAD1CAC0DABFA8D653CFF82FE43F'::geometry,
0);"
PL/pgSQL function "totopogeom" line 125 at EXECUTE statement
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1641>
