[postgis-devel] [PostGIS] #1641: SQL/MM Spatial exception - geometry crosses an edge
PostGIS trac at osgeo.org
Thu Mar 1 05:41:05 PST 2012
 Reporter:  lrssvt    |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Comment(by strk):
 I suspect the default "0" tolerance should be taken as "float8" tolerance
 which is an expanding grid starting from EPSILON at the origin. This is
 what I've implemented in the last two cases.
 Anyway there's not yet a well-defined semantic for such "tolerance".
 Research topic: wiki:ToleranceDiscussion
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1641#comment:2>
