[postgis-devel] [PostGIS] #1641: SQL/MM Spatial exception - geometry crosses an edge
trac at osgeo.org
Thu Mar 1 06:16:33 PST 2012
Reporter: lrssvt | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: 2.0.x
Keywords: |
Comment(by strk):
Alright in this case noding of the two lines results in the line being
added (the semi-vertical one) being split in two. Then first point is
added as a node (the lowest) and when last point is added as a note the
code fails to find this second node _on_the_ existing line.
The query is in the form: ST_Dwithin(intersection_node, existing_line, 0)
Well, it fails. Using a tolerance of 1e-17 still fails. 1e-16 succeeds in
finding it.
This part of the code isn't attempting to do any tolerance. We could add
that.
But still, what GEOS does is completely out of our control as GEOS uses
its own heuristic to get to a result, responding to topology exceptions by
reducing precision (for example). So it could still be possible for us to
use a too low tolerance to account for what GEOS did.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1641#comment:5>
