[postgis-devel] [PostGIS] #1639: [raster] MapAlgebraExpr can't handle conditions
trac at osgeo.org
Thu Mar 1 07:20:07 PST 2012
Reporter: nicklas | Owner: pracine
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.0
Component: raster | Version: trunk
Keywords: |
Comment(by dustymugs):
Strange that this isn't working. Concise example:
DROP TYPE IF EXISTS cellset CASCADE;
CREATE TYPE cellset AS (
x integer,
y integer,
value double precision
CREATE OR REPLACE FUNCTION dump_cells(rast raster, band int DEFAULT 1)
RETURNS SETOF cellset
AS $$
DECLARE
r cellset%rowtype;
rows int;
cols int;
BEGIN
SELECT width, height INTO rows, cols FROM
ST_Metadata(rast);
FOR r IN SELECT x, y, ST_Value(rast, band, x, y)
FROM generate_series(1, rows) AS x
CROSS JOIN generate_series(1, cols) AS y
LOOP
RETURN NEXT r;
END LOOP;
END;
LANGUAGE 'plpgsql';
WITH foo AS (
SELECT
ST_AddBand(
ST_MakeEmptyRaster(5, 5, 0, 0, 1, -1, 0, 0, 0)
, '8BUI'::text, 1, 0
AS rast
SELECT dump_cells(rast)
FROM (
SELECT
ST_MapAlgebraExpr(rast, '8BUI', 'CASE WHEN [rast.x] % 2 =
0 AND [rast.y] % 2 = 0 THEN NULL ELSE 128. END') AS rast
FROM foo
) bar
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1639#comment:3>
