[postgis-devel] create extension is not working
Jose Carlos Martinez jomarlla at cgf.upv.es
Thu Mar 1 10:45:15 PST 2012
Im getting this message building the postgis extension (The
postgis_topology extension was built correctly though):
---- Making install in postgis
make[2]: Entering directory
`/home/alumno/Downloads/postgis/extensions/postgis'
make[2]: *** No rule to make target
`../../postgis/postgis_drop_before.sql.in.c', needed by
`sql_bits/postgis_raster_upgrade_minor.sql'.  Stop.
On 01/03/2012 15:44, Jose Carlos Martinez wrote:
> Dear List,
> After building successfully the last r9365 I cant create the postgis
> extension:
> h0=# create extension postgis;
> ERROR:  syntax error at or near "BOTH"
> Not sure if it is my fault though.
> Someone is having the same problem?
> Regards,
> Jose
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
