[postgis-devel] Raster support in 2.0.0
Devrim GÜNDÜZ
devrim at gunduz.org
Thu Mar 1 11:02:44 PST 2012
I began testing packaging PostGIS for Fedora/RHEL/Scientific
Linux/CentOS and others. So far it seems pretty fine, but I'm having
some issues with raster support.
To add raster support to PostGIS, I need to install gdal-devel package,
and the current gdal package in Fedora/EPEL repositories are not aware
of the new PostgreSQL RPM layout. I can make it aware, but then:
armadillo-devel is needed by gdal-1.9.0-1.f16.x86_64
cfitsio-devel is needed by gdal-1.9.0-1.f16.x86_64
CharLS-devel is needed by gdal-1.9.0-1.f16.x86_64
chrpath is needed by gdal-1.9.0-1.f16.x86_64
freexl-devel is needed by gdal-1.9.0-1.f16.x86_64
hdf-devel is needed by gdal-1.9.0-1.f16.x86_64
hdf-static is needed by gdal-1.9.0-1.f16.x86_64
hdf5-devel is needed by gdal-1.9.0-1.f16.x86_64
jasper-devel is needed by gdal-1.9.0-1.f16.x86_64
libgta-devel is needed by gdal-1.9.0-1.f16.x86_64
libspatialite-devel is needed by gdal-1.9.0-1.f16.x86_64
netcdf-devel is needed by gdal-1.9.0-1.f16.x86_64
libdap-devel is needed by gdal-1.9.0-1.f16.x86_64
librx-devel is needed by gdal-1.9.0-1.f16.x86_64
mysql-devel is needed by gdal-1.9.0-1.f16.x86_64
numpy is needed by gdal-1.9.0-1.f16.x86_64
ogdi-devel is needed by gdal-1.9.0-1.f16.x86_64
poppler-devel is needed by gdal-1.9.0-1.f16.x86_64
xerces-c-devel is needed by gdal-1.9.0-1.f16.x86_64
xz-devel is needed by gdal-1.9.0-1.f16.x86_64
and it means more build dependency to RPM buildfarm.
So, the question from the "non-GIS and just a packager guy" is: How
critical is raster support? Is it ok if I just ditch it out from the
spec file?
Regards,
Devrim GÜNDÜZ
Principal Systems Engineer @ EnterpriseDB: http://www.enterprisedb.com
PostgreSQL Danışmanı/Consultant, Red Hat Certified Engineer
Community: devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
http://www.gunduz.org Twitter: http://twitter.com/devrimgunduz
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120301/dee8a69d/attachment.sig>
