[postgis-devel] [PostGIS] #1139: [raster] Values, when clamped, should not be set to nodata value
PostGIS trac at osgeo.org
Thu Mar 1 17:21:22 PST 2012
  Reporter:  pracine  |       Owner:  dustymugs
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  raster   |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by dustymugs):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Fixed in r9380.  This is only in effect for rt_band_set_pixel(), not
 rt_band_set_pixel_line().
 The criteria used for correcting a clamped value is:
 1. If boolean type, value other than NODATA value.
 2. If integer type, value is decremented by 1 unless the clamped value IS
 the minimum value possible for that pixel type where the value incremented
 by 1.
 3. If 32-bit floating point, value is decremented by FLT_EPSILON (minimum
 positive floating point number of type float) unless the clamped value IS
 by FLT_EPSILON.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1139#comment:3>
