[postgis-devel] [PostGIS] #1639: [raster] MapAlgebraExpr can't handle conditions
trac at osgeo.org
Fri Mar 2 00:44:53 PST 2012
Reporter: nicklas | Owner: pracine
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.0
Component: raster | Version: trunk
Keywords: |
Comment(by nicklas):
I don't think it is working. The output is wrong, at least from my box.
I get true in all cases or false in all cases.
I also get the same result if I send the result to '8BUI' pixeltype so the
problem seems to be in the expression not the cast to boolean.
What casts is actually happening? Why do you cast to integer in your
example when the result from the expression is boolean and the result
pixeltype is boolean. The error-message if I don't do that cast is that it
can't be casted to double precision.
Can it be all those casts that is making things bogus after all?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1639#comment:10>
