[postgis-devel] [PostGIS] #1630: upgrade from alpha6 to beta1: wktgeomval type can't be dropped; cannot change input parameter nodata; can't drop raster_columns (was: upgrade from alpha6 to alpha7SVN: wktgeomval type can't be dropped; cannot change input parameter nodata)
PostGIS trac at osgeo.org
Fri Mar 2 05:27:46 PST 2012
  Reporter:  robe                   |       Owner:  strk
      Type:  defect                 |      Status:  reopened
  Priority:  blocker                |   Milestone:  PostGIS 2.0.0
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:                         |    Keywords:
Comment(by robe):
 Well this is mighty annoying.  My luck for not having time to test the
 final beta1.  Just tried to upgrade my freshly installed alpha6 to beta1
 and got --
 Can't drop raster_columns because other objects depend on it. extensions
 postgis depends on it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1630#comment:11>
