[postgis-devel] [PostGIS] #1639: [raster] MapAlgebraExpr can't handle conditions
trac at osgeo.org
Fri Mar 2 05:30:27 PST 2012
Reporter: nicklas | Owner: pracine
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.0
Component: raster | Version: trunk
Keywords: |
Comment(by pracine):
Replying to [comment:14 nicklas]:
> If I cast to Integer and put it in '8BSI' like this:
> Then I would expect the false results to show as 0, right?
Yes, but still 0 is nodata.
> But I still get the same result (nodata as I have learned now :-) )
Seems normal to me.
> To do this calculation in PostGIS it takes about 45 seconds, but in QGIS
with the same images as geotiff it takes less than 2 seconds.
I guess a real comparative test with QGIS would be to open the image and
make the calculation but yes, we still have a lot of work to do on our map
algebra to compare with QGIS or Arc.
> But it can be because PostGIS can't gain fully from the SATA3 ssd on
this box while maybe the file based gdal calculation through QGIS can?
I'm afraid it won't make much difference...
> Or is it some casts that is giving a false bottleneck?
We still have to find the bottleneck but I guess it is in the great
flexibility of our expression parser. With flexibility comes slowiness. We
will have to think about the avenues we have to make it faster. I think
there are many.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1639#comment:15>
