[postgis-devel] use of xsltproc at docs-install time?
Greg Troxel
gdt at ir.bbn.com
Sun Mar 4 07:14:34 PST 2012
My system doesn't have the mathml dtd (I need to package it; thanks for
the pointer), so I am using the command-line flags method to avoid
--no-net, which is fine.
I added "XSLTPROCFLAGS=" to invocations of make, and make docs, but not
make install, make check, or make docs-install. I found that at least
docs-install seems to run xsltproc, which seems wrong (I wouldn't have
noticed before, but with --no-net being passed it fails).
Other than that, the full make check (postgis, raster, topology) has
been generally passing on NetBSD/i386 5.1ish; I tend to update every
other day and kick off a full build/test.
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120304/8cf6b71a/attachment.sig>
