[postgis-devel] [PostGIS] #1648: ST_AsRaster unexpected result
trac at osgeo.org
Mon Mar 5 11:26:07 PST 2012
Reporter: jomarlla | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
create table rast2 as
select ((pol).geom)::geometry (polygon, 0) as geom,
(pol).val::integer as value
from (select st_pixelaspolygons (rast) as pol from
(select st_asraster ('POLYGON ((11 11, 21 11, 26 21, 16 21, 11
11))'::geometry,
1.5::double precision, 2::double precision, 11, 11,
'8BUI', 100, -1, 0, 0, true
) as rast
) as tabla) as tabla1;
Im getting a cell which is not burned.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1648>
