[postgis-devel] [PostGIS] #1651: make check runs xsltproc, without XSLTPROCFLAGS
trac at osgeo.org
Mon Mar 5 17:52:05 PST 2012
Reporter: gdt | Owner: strk
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.0.0
Component: build/upgrade/install | Version: trunk
Keywords: |
With r9403, make check calls 'make -C doc comments-install', which runs
xsltproc. This is probably a bug, but it's surely a bug that XSLTFLAGS
are not passed down to the comments-install target. (I had been passing
XSLTPROCFLAGS=--LOSE in order to cause xsltproc invocations to fail on
other than build invocations of make.)
Alternatively, this can be viewed as a bug in README.postgis, that doesn't
explain that a) a doc toolchain is necessary for make check and b) one
must have built comments before running make check.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1651>
