[postgis-devel] [PostGIS] #1647: CreateTopology vs toTopoGeom: different behavior on the use of tolerance
PostGIS trac at osgeo.org
Tue Mar 6 01:05:20 PST 2012
  Reporter:  lrssvt    |       Owner:  strk
      Type:  defect    |      Status:  closed
  Priority:  medium    |   Milestone:  PostGIS 2.0.0
 Component:  topology  |     Version:  2.0.x
Resolution:  fixed     |    Keywords:
Changes (by strk):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Good catch, toTopoGeom was failing to use the tolerance argument. Fixed
 with r9404
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1647#comment:2>
