[postgis-devel] [PostGIS] #1650: Invalid edge (no two distinct	vertices exist)
    trac at osgeo.org
    Tue Mar  6 02:01:00 PST 2012
 Reporter:  lrssvt    |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Comment(by strk):
 One of your edges is shorter than 2, what do you think postgis should do
 in that case ?
 =# select id, st_length(wkb_geometry) from test.pipes;
  id |    st_length
   1 |  1.6405966228982
   2 | 129.304797905447
 (2 rows)
 I guess these are the options:
  1. Add _nothing_ to the topology, return a NULL TopoGeometry
  1. Add _nothing_ to the topology, return an EMPTY TopoGeometry
  1. Add a single node to the topology, return a NULL TopoGeometry
  1. Add a single node to the topology, return an EMPTY TopoGeometry
  1. Add a single node to the topology, return a Puntal TopoGeometry
 Note that a Puntal TopoGeometry will fail to be inserted into a Lineal
 layer.
 I'm not sure this is to be considered a bug.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1650#comment:1>
