[postgis-devel] [PostGIS] #1650: Invalid edge (no two distinct vertices exist)
PostGIS trac at osgeo.org
Tue Mar 6 07:31:31 PST 2012
  Reporter:  lrssvt    |       Owner:  strk
      Type:  defect    |      Status:  closed
  Priority:  medium    |   Milestone:  PostGIS 2.0.0
 Component:  topology  |     Version:  2.0.x
Resolution:  fixed     |    Keywords:
Changes (by strk):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 Sorry, I take it back, that's not the query. I'll wait for a separate
 ticket to deal with this.
 It's about adding an edge failing to snap to an existing node.
 To reproduce: add one point, then add a line which is within tolerance
 distance from the point.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1650#comment:14>
