[postgis-devel] [PostGIS] #1657: Crasher on ST_AsLatLonText on mingw64 in combo query_to_xml
trac at osgeo.org
Tue Mar 6 20:39:59 PST 2012
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: mingw64 |
So took my new postgis 64-bit windows for a spin and since I don't have
make check working yet. Ran it thru my garden tests. It seems to
consistently crash when it tries to log the output of an invalid
ST_AsLonLat. It got thru the postgis 1.5 tests still standing though.
SELECT query_to_xml('SELECT ST_AsLatLonText(foo1.the_geom, ''monkey'') As
result FROM ((SELECT ST_SetSRID(ST_Point(i,j),4326) As the_geom FROM
(SELECT a*1.11111111 FROM generate_series(-10,50,2) As a) As i(i) CROSS
JOIN generate_series(40,70, 5) j ORDER BY i,j )) As foo1 LIMIT 3;',
false,false, '');
After I restart it, I have to run this test about 4 times before it kills
the server again. Haven't tried it on my mingw32 builds recently.
I also can't make it crash unless I combine it with query_to_xml which is
what I use to log the results.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1657>
