[postgis-devel] [PostGIS] #1666: make_dist.sh does not add postgis_svn_revision.h
trac at osgeo.org
Wed Mar 7 16:37:03 PST 2012
Reporter: mwtoews | Owner: chodgson
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: management | Version: trunk
Keywords: |
When running `make_dist.sh sometag`, an error appears:
> Can't open perl script "utils/svn_repo_revision.pl": No such file or
directory
.. and so the `postgis_svn_revision.h` files does not make it into the
distribution.
Do we want this file for releases? There is some discussion regarding this
file in #1634. If it is desirable, see attached patch.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1666>
