[postgis-devel] [PostGIS] #1668: ST_AsText, ST_AsEWKT under Windows 64-bit PostGIS 64-bit is all screwy
trac at osgeo.org
Thu Mar 8 07:50:34 PST 2012
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: mingw64 |
I was willing to dismiss this as something I was doing wrong during
compile, when I tried compiling PostGIS 1.5 under my mingw64 and
discovered that it did not exhibit the same screwy behavior. So now I'm
not sure where the error is.
The PostGIS 1.5 64-bit compiled version doesn't have issue with ST_AsText.
Here is an an example:
SELECT ST_AsText(ST_Buffer(ST_GeomFromText('POINT(1
2)',4326),1,'quad_segs=3'));
-- under PostGIS 1.5 64-bit mingw64
POLYGON((2 2,1.86602540378444 1.5,1.5 1.13397459621556,1
1,0.500000000000002 1.13397459621556,0.133974596215563 1.5,0
2,0.133974596215559 2.5,0.499999999999997
2.86602540378444,0.999999999999995 3,1.5 2.86602540378444,1.86602540378444
2.50000000000001,2 2))
-- under PostGIS 2.0.0beta2 64-bit mingw64
1,0.500000000000002 1.13397459621556,0.133974596215563 1.5,0 2, 2.5, ,
3,1.5 2.86602540378444,1.86602540378444 2.50000000000001,2 2))
Note the ,s with no numbers.
I think the underlying geometry is fine, because if I do an ST_AsGML (my
32-bit and 64-bit installs of PostGIS 2.0.0 agree)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1668>
