[postgis-devel] [PostGIS] #1666: make_dist.sh "pre-2.0.0-tag" does not add postgis_svn_revision.h
trac at osgeo.org
Thu Mar 8 09:38:17 PST 2012
Reporter: mwtoews | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: management | Version: trunk
Resolution: wontfix | Keywords:
Comment(by pramsey):
The important thing is to note that when building with make_dist.sh the
"get revision" script is *not* being run inside an SVN checkout, it's
being run in an svn export, so it has no local access to svn revision
information. It needs to run with the svn tag url to go online and pull
the revision number from the tag. As long as you're doing that, everything
wlll be OK.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1666#comment:3>
