[postgis-devel] [PostGIS] #1670: Update main README
PostGIS trac at osgeo.org
Thu Mar 8 17:49:41 PST 2012
 Reporter:  mwtoews        |       Owner:  robe
     Type:  task           |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.0
Component:  documentation  |     Version:  trunk
 Keywords:                 |
 I've made many changes to the `README.postgis` file:
  * Use consistent formatting in reStructuredText - some was, some wasn't.
 To view result, copy/paste the file text into
 http://www.tele3.cz/jbar/rest/rest.html
  * Wrap lines to 80 columns, trim trailing whitespace, replace tabs with
 space chars
  * Fix typos, and use consistent case and punctuation
  * Merged some content from `README.raster` (I hope); see #1649
  * Alphabetize the directory structure
  * Add `./libpgcommon` to directory structure, and attempt to describe it
  * Mention that both Raster and Topology extensions are built by default,
 add notes how build without them
 Other notes:
  * There are probably other things that should be improved, such as how to
 spatially enable a 9.1+ database using extensions
  * Could this file be moved back to `README`? (`svn move README.postgis
 README`)
  * I'm not sure if mentioning `apt-get` commands is a great idea, since
 there are many package managing solutions (`yum`, etc.), and different
 distros have different names for these packages (e.g., `-devel`). I have
 started (but not completed) UsersWikiInstall to address platform specific
 instructions (which should probably get mentioned somewhere)
 I really don't expect this patch to be applied as-is, since there are
 probably several improvements to include (or not!).
 I've attached both the whole file and a diff patch.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1670>
